Hi all. Yup, time for another long weekend! We'll be back to it Tuesday morning, so until then, keep them solar cells clean!
Got a new kit for you - the K SMD L293D Motor Driver. No, no, the SMD isn't "surface mount" - it's the Secret Motor Driver! This L293D-based motor driver fits secretly inside most standard servo cases like the Futaba S3003/S148, and our own GM4 gear motors. It replaces the low-voltage original electronics with LED-indicated, 1.2A powered, 36V capable, logic-compatible signal circuitry!
The 'Secret' motor driver board is ideal for mini-sumo robots, breadboarding motor circuits, or anywhere else where you need a compact, reliable circuit to drive your motor using standard logic level (not servo PWM) signals.
Introductory Special: Get two for $20USD ($30CDN)!
We're happy to announce that the 2001 Los Alamos BEAM Robotics Workshop is going ahead this May 3 to 6th! After much delay and threats of budget-cuts, funding has finally been secured. Thanks to Joe Vigal and Paul Argo of the Los Alamos National Laboratories for keeping this great event alive for this final year! […]
Solarbotics in Canada Computes! We were recently interviewed for an article in the widely-read (well, in Canada anyways) Computer Paper publication. Probably nothing you already know, but we like to toot our own horn. Read More...
Seeed Raspberry Pi Breakout Board v1.0 $14.95 The Raspberry Pi Breakout Board for Raspberry Pi is a prototype board that allows you to combine your Raspberry Pi with other components and modules. Grove - Light Sensor(P) $3.75 Panel mount light sensor from SeeedStudio. XBee WiFi Module - Wire Antenna $52.75 This is the XBee WiFi […]
