Circuit: Shok
Dave Hrynkiw
July 12, 2007
ShokPopper & ShokPhoto-head
You want a simple Photovore? This very tidy design by Solarbotics' own Grant McKee is based on a technique developed by Mark Tilden - Shok architecture:
Here's video of the test robots being tuned as a 177kB Windows Media Format (WMV) file or as a 168kB RealMedia (RM) file.
ShokPopper V1.0 (click for circuit diagram) - GrantM Aug 2001
Theory of operation:
"Shok" architecture is a technique pioneered by Mark Tilden describing controlled state changes of Bicore style circuits via chip power or enable toggling. When a Bicore circuit is powered on, it will resume a state opposite to what it was when it was powered off, this effect can either be duplicated by pulsing the enable line or by pulsing power to the chip itself. This is called "shoking" the Bicore. The power-on state can also be pre-determined by biasing the voltage across the Bicore capacitors. A photodiode attached directly across the Bicore charge capacitor will pre-bias the shoked output. The addition of tactile sensors is easily implemented by attaching a switch from the input of the Bicore to +Vdd. When the switch is closed, it forces that side high, presetting the state of the Bicore on the next pulse cycle.
Probably one of the simplest photovore circuits to date, the core circuit consists of a 6 part count and a solar-engine. Either 74AC240 or 74HCT240 will work but we recommend using the AC series for better output drive current. The ShokPopper will not work under battery power unless the enable line is pulsed.
Solar Engine to use with Shok:
The best solar-engine to use is the Miller engine. For the ShokPopper Photovore we used a Miller engine consisting of:
  • CP3300uf cap
  • 1381Q
  • CP1µf timer cap (0.47µf will work fine as well)
  • 2N2222 Transistor
  • SC3733 Solarcell
  • D1 1N914 Diode
The Bicore Circuit Consists of:
  • 74AC240 Octal Buffer Chip
  • TR100k Trimpot
  • 2 x 0.22µF Capacitors
  • 2 x IR1 Infrared Sensors
  • 2 x RM1 Motors
  • TACT2 Spring Sensor Kit (Optional)
The Miller engine switches the ground line of the circuit.
The theory of operating is very similar to that of the shok popper except that the head now only uses one motor, the photo head does not "lock" on but will continually seek for the brightest source of light. Nice effect if you want a continually seeking, dynamic device on a stationary base.
  • 74AC240 Octal buffer chip
  • 4 x CP0.1µF capacitors
  • 100k resistor
  • 2 x 47k resistors
May 23, 2013
Thursday Cool Links
Well, it looks like we somehow managed to walk away from the Maker Faire unscathed. Going to the beach afterwards, though, has left us with some residual sunburns to suffer through. Thankfully, we got to return to some local weather that is wet, grey, and generally miserable. But enough of that! On with some neat-o […]
January 17, 2018
New Product Post
3W Stereo Bluetooth Interface, 3.7~5VDC, FM / TF/ USB, IR $18.20CAD / $14.50USD We are impressed with this stereo Bluetooth v4.2 module with USB, SD card, or Bluetooth audio inputs and a remote control driving a 3W amplifier. 3W Stereo Bluetooth Interface, 3.7 ~ 5VDC $12.67CAD / $9.50USD A basic bluetooth speaker driver board, ideal […]
February 13, 2019
Zelda themed DIY LED Valentine's Day car...
Create an awesome Valentine's Day card with this DIY project! This card will surely bring a smile to the face of any die-hard Zelda gamer and showcases a fun way for beginners to make a unique DIY gift using simple items and cool electronics. You can really get creative by using strips of copper foil […]
December 9, 2010
Parallax S2 Scribblers in stock
The new S2 Scribblers from Parallax are in, and they feature a couple of cool new features. First: They're Open-Source! Yup, they've opened up all the design files to make hacking oh-so-much easier! Secondly, it's using the Parallax Propeller chip now, for mucho-improved computational power. They're already out of stock at Parallax, so get them […]
