The instructions for assembling the Pi v3 and the previous acrylic Pi SAFE are quite similar. The only difference between the models is the location of the LED light pipes, so these Pi3 instructions apply generally to all Pi SAFE versions.
1. Your Parts!
8 x 4-40 nuts
8 x 4-40 x 3/8" bolts
2 x Clear acrylic light-pipes
4 x Black acrylic spacers
6 x Black acrylic SAFE sides (shown here with brown protective paper already removed)
0 x Raspberry Pi (sorry - not included in the kit!)
2. The Baseplate
Find 4 of the 4-40 x 3/8" bolts, and put them through the baseplate, and press the spacers on from the other side. Thee bolts will sort of stay put until you can get the Raspberry Pi on the baseplate. (If adding to a VESA mount, do only 2 diagonal screws)
3. Adding the Raspberry Pi
Slide the Raspberry Pi onto the bolts. The Pi is designed for metric M3 hardware, but we're still using imperial #4 hardware, which is a smidge bigger. The bolts may need to be screwed through the holes in the Pi.
Add the #4 nuts, and tighten them down.
4. Adding 3 of the 4 Sides
Arrange the sides as shows. The sideplate on the top in this image has the long cutout to accommodate a ribbon cable from the 40-pin expansion port. The front faceplate on the right (with the label engravings face-down) is for the communications side. The sideplate on the bottom has the ports for the power, video, and audio I/O.
Align them all up on the baseplate, and use a pair of 4-40 nuts and bolts to lock them in place.
5. Adding the SD-Card / LightPipe Faceplate
Lay the final side faceplate face-down beside the assembly, and pop the clear lightpipe parts out of their holder. It is not necessary to strip the paper off this part.
Sandwich the two lightpipes together, and push them into the lightpipe indicator hole. They will sit a bit loose until the faceplate is attached to the baseplate.
Carefully assemble this assembly to the baseplate, and finish attaching it with the remaining 4-40 nuts and bolts.
Step 6: Top Plate mounting
Notch the top plate into the slots in the rear faceplate, and gently flex the frontplate out to let the tab snap into place. You're ready to power up, with full access to the indication LEDs on the Pi mainboard via the lightpipes!
Psst. Hey. You. I have a secret. A secret we want everyone to know about. But only the people going to the San Fransisco Maker Faire. The word 'free' is a pretty good word, right? Let's throw 'Arduino' in there too. We may be onto something here... How about 'workshop', just for good measure? Those […]
Cosplay at Solarbotics We have a bit of a rule here. If there's a project we want to do, somebody has to have the passion for it. The drive, the dedication, the "kick-the-right-people-in-the-butt-to-get-it-done" drive. In this case, the project is a Rainbow Brite Dress, as spear-headed by our warehouse chief-elf Lyn Janelle (costume concept, design […]
Freezer Burn is an Alberta Regional Burning Man celebration annually creating a temporary community out on the prairie. A few of us here at Solarbotics attend, and having access to all of the neat technology, we make an effort to bring special projects to the festival. Lit up projects work well since the event is outdoors […]
Warning: This product contains chemicals known to the State of California to cause cancer and birth defects or other reproductive harm. Please visit www.P65Warnings.ca.gov for more information. This item was manufactured prior to August 31, 2018.
